New TSB issued today for P0514 and more
2006 engine noise
3rd gen engine R&R
jandr said:
Would/could that be from the fuse missing? I was checking fuses (because I burnt the power outlet fuse with a devise) and was going through the chart inside my cover. Fuse #30 is marked as a 15 amp spare but when I used it temporarily, the ABS and Brake warning lights stayed on. I pulled over and put a fuse in there and they went out. Maybe that's it?
On a side note, #'s 3,34 and 41 are marked spares and are lose so the are spares. #'s 17, 30 and 37 push in tight (internal connectors) but are still marked spares. I now know at least #30 is NOT a spare.
My cover chart is wrong.
Thanks for the code definition. I read another guys post that after correcting (I think) the problem, his chk eng. light went out after 5 or so start ups. Does that sound about right?
Yes all modules need their powers and grounds to communicate,so a missing fuse would do it.
The abs light will go out right away after fault is repaired. Ck engine light will go out after a # of good trips.
Thank you very much for the input. My light has gone off now. I will see if the P0514 and P0111 codes throw again. I also believe there were other issues that may have caused those so we will see.
