lmills said:no, it is definitely adjustable timing.It was a design they brought forth from so many people wanting the ability to stack boxes and not worry about timing getting out of control.
BSwope said:Wonder if they will come out with a different remote? Something like the PDA maybe?
Just thinkin out loud thats all!
JHedman said:Well. . I talked to Mark yesterday morning and have found out that I don't have the new adjustable timing feature. Which comes as a suprise, but I'll work that out later.
Anyway, according to him the boxes and remotes with that "flash or firmware" have two additional menu screens after the usual on the R49 remote. The first one allows you to set the maximum advance of timing that the box uses. Say for instance there is no injector clatter until you reach 12 degrees of timing you can limit the box so that it will only advance the timing to a maximum of 10 degrees.
The second menu allows you to disable the automatic timing of the box and set a degree of timing that it stays at. Irregardless of the boost or aceleration. So if your stacking the TST with a box that also advances the timing you can adjust the TST to work with the other boxes curve.
mhlbr said:I am calling them as we speak![]()
