Finally did my first pull with the new Super B. Good test too, as the south wind was strong. Did not have time to slide the plate back to where it was two weeks ago, when I thought I was going to dyno. With it full forward, I can run strong at 68 mph or so with 30 plus psi and keep the egt's less than 1100 degrees. The fifth wheel is heavy and catches a lot of wind, so I think I have made a good improvement over the hx35. This thing will run 35 psi or more with no problem. Think I will slide the plate back a tad and see if it will hold the load as it does now. Guess I am trying to say I am pleased. Now, if I can just get this BD exhaust brake to work as the old Ram Brake did. Time to get back on the line with Pat.
