Timbeaux38 said:He must have a very special box... ... ... ...
The guy I know of is on stock charger and injectors, but has 2 boxes
Um, Yeah... The single box 550 was a one off Van Aaken made for him at PDR dyno day 04. It was smokin. However it does not stack well. Sounds like you dumped a box of marbles into the crank case when you lift on the go pedal.
Juices normal stack is the Comp Hot Juice and Bully dog power pup( 220 HP version I think, but don't quote me, he changes every now and then). However he has not made a full dyno run with that setup yet.
With the stack (before the twins) I have seen him make enough WOT smoke to make a 12V with 370's blushe. :-laf
If he is able to get the stack to work with the twins and burn all that fuel... I would say 600-650 should not be a problem. Oo.
