Engine/Transmission (1998.5 - 2002) New Van Aaken Module, no difference felt.
2nd Gen Non-Engine/Transmission '07 wheels
Engine/Transmission (1998.5 - 2002) Crank sensor failure... Help please...
Just got my Van Aaken module today. Installed it when I got home and took it for a test drive. Didn't feel any different to me. I could only build 20lbs boost, could this be the problem?
If you want more boost, etc. You need one check out TDR basement enterprises I think somebody sells them there. Like 15 or 20 last time I checked. well worth it.
Bobalos, you hit that much boost b/c of the extra fuel you have (more than a VA and you have a different turbo(HY 35, its a little smaller w/ a 9cm housing) than us manual guys (HX 35 w/ 12 cm housing)... . but your truck should defuel at 22 without out a chip on it... I am assuming that was with the bully dog stuff on there... you would need what is called a j-hook. It holds the waste gate closed until around 32-34 psi. With just my injectors(DD3's) and smarty I could get 32 lbs with no wg mods... but then it would slowly open up and drop down to 23 or so. Waste gate mods stop that.
Got a boost elbow ordered and on the way. Did some more driving around today. I guess maybe it is working, it will build boost quickly to 20psi, just seems to want to build more elbow should fix that. I can make the boost gauge jump by blipping the throttle, couldn't do that before. It does run a lot smoother and quieter also.
Got my Boost elbow last night. Took a drive over lunch, I can get it up to 24psi. EGT's come up to 900 pretty quick and then seems to flatten out and creeps up to about 1050. what size injectors can I go up to and still keep it safe?
Those pre turbo temps? Seem pretty cool for having a box on there! I could hit 1350 with my EZ box if I lugged it... . Under normal hard accel 1300 wasn't out of the question...
