Newbie, "thump" question.
installing a EZ box (compliments of BILL K.)with a powermax3??
Auto Trans - Help !
Great site! I've been reading since October... lots of useful and friendly advice. My question is regarding the "thump" sound that some of you have been talking about when the ignition key is first turned on. My truck doesn't make that sound, but I have a buddy with a '99 3500 4x4 auto and his DOES make it. What's the deal? Should my truck also "thump" or does it matter? Thanks for the info.
'99 2500 Quad Cab, 4x4, Auto, 3. 54, 265/75R16's, EZ, K&N, no silencer ring
I was told that the "thump" sound was from the ABS system on trucks with 4 wheel ABS.
My truck has 4w ABS and does make the noise. The noise will be much less if you put your foot on the brake pedal before starting. Hope this helps. Dan #ad
Flame Red 98. 5 2500 4 X 4. 285/75/16 2"lift in the front to level it out with a 8274 Warn wench. Hiway aluminum 5th wh. tool box. 32'Alfa 5th wheel w/2 slides. 1 pair of black truck nutz under the rear because it's a RAM not a ewe. K&N air filter,VDO pyro,boost and trans gauges on the "A" pillar, soon DDT tc/vb
