I wouldn't call that power.
I call that an appetite for destruction!!
You're right, lets pump this thing up... so what turbo to go with? And if I put on the turbo and FASS system, what else can I do to get more power other then the DDII's and Comp box? And give me some $$$$$ figures.
Well JEEZ!
- that's a sudden change of thought! How much are you setting aside to do this increase?
I would:
1) Turn down that box!!:{ - I know it hurts you to do this BUT DO IT.
2) Atleast look into the AFE- you don't have to fabricate mounts,shields or anything! Pop the hood open stock box- pull K&N out (throw like a frisbee towards the nasty neighbors house:-laf ) Loosen 3 bolts that hold the factory box on, loosen hose clamp on the turbo feed, remove the filter minder- and throw on the AFE kit with same 3 holddowns, install feed- tighten hose clamp, push in minder grommet- push in minder- DONE!- no rigging!
3) Decide how much your willing to spend on the next turbo... .
The HX-35-40Hybrid would be step 1
The full on HX-40 would be step 2
The PDR HX-40 (with the oiling modification) would be a better 40-to get specify 4" downpipe use- (and get the 4"downpipe!) would be step 2. 5
The B1 line of turbos are known as a tough turbo, beefy shaft- great spool, great at cutting the E. G. T. 's down. Depending on which B1 you choose, they have different versions they range in steps 4,5,6,7.
Anything after this and I feel you need to look for a twin setup
There are a few other turbo choices in between- some prefer the HTB line- some like others- Ken Diaz at Turbo Auto Diesel- has a good handle on the B1 line.
4) Injectors-The bigger the turbo you decide on would tell you if the injectors need to be changed, example- your DD2's- if you keep them would be good for the 35-40 hybrid- you'll want something like 3's or 4's when you go with the 40.
B1's you'll want 4's or 5's maybe even 6's depending which B1.
5)FASS Kit- popular set up- there are others- up to you.
6) 4" Turbo Downpipe.
But how wild you go- really depends on the budget allowed.
