Newby Question: Winter Fuel Economy; Color of Fuel
2014 3500 SRW Unloaded Rear Tire Pressures
Looking for Pictures/Ideas for Nerf Bars on 2014 Ram 3500 CC
The internet is a pretty big place, and with a simple Google search one can usually find evidence to support just about any valid point. For your above post, I cannot find anything to support what you are saying. However, I can find results that contradict what you have posted. You should try fact-checking before hitting the "submit" button.
1. Ambient temperature has nothing to do with a fuel's BTU output. I cannot find anything that states otherwise. And somehow you're trying to connect the cloud point of diesel (20*F on the high side btw, not 40F) with BTU output...? Again, nothing.
2. "It is not the BTU's that generate the power it is the expansion of the gasses that push the piston." <- That one tells me you don't know what a British Thermal Unit represents in the world of physics. What do you think causes the gasses to expand? Knowing the BTU content of the fuel, with a little converting and a couple equations you could determine exactly how much pressure would be in the cylinder pushing on the piston. Google it - they're pretty standard gas laws.
3. Yikes. Any engine with a cam that has valve overlap (exhaust and intake open at the same time) is taking advantage of scavenging. Every cam available for our engines has overlap. Scavenging is based on a continuous acceleration of the gasses through the engine, and that is enhanced by having the greatest temperature differential possible between intake and exhaust. Being turbo'd is irrelevant - charge pressure is close to exhaust pressure, so anything you can do to improve the airflow through the engine still counts. I'm not sure where the rest of your thought was going on that one since you kinda went off the rails.
4. Totally off the rails at this point. Nothing valid enough to reply to. Even how you used my quote doesn't make sense. A little PUI, methinks. Interesting perspective on cold weather ops from a guy in Georgia though.
I can't argue with fiction. As I've asked before in other threads, please provide links to proof of your claims. Maybe this one time you might take me up on it?
LMAO!!!! Your read it on the internet so it must be true, you can't find it on the internet so it must be fiction. That is wrap!!! :-laf:-laf
It is wrap indeed. PUI early, eh?
It's pretty easy to tell when you're busted posting fiction, because you follow up with posts such as the one I've quoted.
There's plenty of actual nonfiction documents put out by various manufactures and organizations that should support your opinions if they are true. Feel free to use those to support your argument.
Unless this was simply you using beligerant arrogance to duck out from actually supporting your side of the argument, that is.
Bring something with some validity to the table and I'll join back in. Otherwise, here you go, have the last word.
Sure Mr GoogleMan, anything you say. What you can't grasp is fiction, what you can't google doesn't exist. :-laf:-laf:-laf
