The plastic bag trick works real good when changing the oil filter..... wish I would have taken the advice in reference to the strap wrench.
Didn't look to bad till I tried to get it under the filter... . there is no room. Had to take my standard oil filter wrench apart to get it around the filter. Other than the wrench problem everything went great. Used a Fleetguard Stratapore and Delo 400. Just a note, Super Duty= fat oil filter and skinny pan plug, Cummins= skinny oil filter and fat drain plug. Does the factory use a thinner break in oil , because my idle oil pressure is at least 10 pounds higher, around 40 psi with the Delo 400? I have aready put more miles on this new oil than my truck had when I drove it off the lot and my oil pressure has never been this high.
