no ac
FCM, Cluster parasitic draw, brake lights on.
why would anybody do this???
The other day I went to push the button for my ac to see if it still worked. The only thing that it did was blink 2 times and went off. This is all I can get it to do. I checked the fuse I could find nothing in that area. I do not even hear the ac clutch kick on at all. Has this happened to any of you out there and if so what did you do.
See if it kicks in in defrost mode... could also be a bad fan clutch. Check for codes also, mine will show P0647, something with high voltage at AC clutch relay.
