2nd Gen Non-Engine/Transmission No brake lights. Help
2nd Gen Non-Engine/Transmission 3rd Gen Wheels
Engine/Transmission (1994 - 1998) Nv5600
1999 2500 all of a sudden bam both rear brake lights out. Flashers work and turn signals must be a fuse not anyway need some help thanks
Yes it was plugged in and in directions said it can be set(adjusted) one time which is not really true but I did have other issues of note.the prices are all over the place 62 at dodge and 11 dollars at napa so shop but the switch is really a tight fit in the metal mount and the plastic ears on the switch break off easily . The mopar part has more space and will fit in better than the napa one but a little work with a file and sharp knife will help to get it in with some plastic removal and angling of the tabs but still a tight fit and rather a pain. To just put in .hope thi. Helps out the next guy. Thanks
