with the cold temps outside i have no brakes on cold engine start ups. the abs light and the brake light are on and the pedal is a hard as a rock to push. after the engine is warm then the brakes are fine,they are also ok if its plugged in a couple hours before starting. i am kinda lost on this one. could the brake fluid be gelling up do to some moisture in the system?? if so ,why does the plugging in of the block heater effect the brakes?? anyone have any suggestions? this problem is on my "94
94 2500 4x4 SLT,auto,180,000 miles,3:54,brilliant blue/silver,tst 250/635,pump turned up 20%,k&n,gauges,cat gutted,
2001 3500 4x4 q-cab slt,auto,4500 miles,3:55lsd,brite silver,stock (for now)both have 12k hitches&15k's in the beds,30ft fourwinds 5er,(MY RAMS) http://albums.photopoint.com/j/AlbumIndex?u=1360183&a=10142301
