Well, had a strange happening this weekend.
First, on a road trip to the coast Friday, the stereo (factory) stopped working but the power stayed on it even with key off and/or fuse pulled.
Then this morning the dash gauges/tach/speedo went haywire (chimes a plenty, lights on dash lit up) - truck ran fine - this was accompanied by the No Bus notification in the odometer window and CCB (or whatever it was) in the overhead display. Did a SEARCH here on TDR and read up on this issue, unhooked the batteries (a bit of gunk on one), wiggled and re-plugged in all the PCM connectors and reset the APPS. OK, started truck up, everything back to 'normal'. Stereo is fine... ... ..... took off an hour later, half a mile from home, the stereo absolutely freaked out - full volume in ONE speaker and the display on the stereo had some hieroglyphics on it. Would NOT respond to any buttons or power off. Pulled the fuse (after cleaning out my shorts)
-stereo finally shut up - but the display on the stereo remains with the key off/fuse out... ... ... .
No gauge dying problem/'no bus' message.
Any other ideas? :{
Any other ideas? :{
