Engine/Transmission (1998.5 - 2002) No bus
The instrument cluster has lost communication with the vehicle's network.
Its a long shot, but sometimes the instrument cluster connector looses good contact. Sometimes just shoving on the instrument cluster can cause the connector to make better contact again.
Another thing to try is connect a code scanner to the OBDII port under the dash and check for proper communication and trouble codes.
Is the engine otherwise running normally?
John L.
See if you can pull any codes up hopefully it is something simple like Landry says but could also be your ecm. If you are able to pull anything up, it may give you a direction to start.
