Archived No fuel prime?
Archived Pilot bearing? ( I hope not!)
Archived help me home
After replacing my delivery valves I cant get the system to prime! I pumped for two hours last night!
I rechecked every connection three times and everything is in order.
This is a simple procedure. But did I miss something?:(
Could the overflow valve that returns fuel to the tank be weak? The primer is working. I cracked the vent at the top of the fuel filter and fuel comes out. But when I crack the lines at the pump-nadda? HELP!!
J. R. :mad:
J. R. ,
Did you try getting ahold of Mark Chapple or Jim Jessup if they are available, or post on the 12 Valve discussion forum.
Maybe call "stroke this" I remember him commenting on working on 12 Valve engines.
Keep us posted, let me know if I can help in anyway!
Running
The truck is back up and running.
Now I have to take the truck in to get the pump calibrated! Lesson learned, DONT MESS WITH THINGS THAT YOU DONT KNOW WHAT THEY DO!!!:eek: Well, I now know what high timing sounds like!:rolleyes:
Any one know what it cost to put the pump on a pump stand?:confused:
J. R. :{
