Just got back from Wyoming (6 hour drive one way) and limped home the last 15 miles in the dark with only my park lights and hazard lights... ?
We thought the headlights lights were working because the dash lights and car-hauler trailer lights were working fine, but then people started brighting us as it got darker. No headlights!??!
When I pull the headlight know out the park lights came on, but the headlights would not come on. When I tried switching between low beam and high beam the lights would come on only while I had the turn signal arm 1/2 way between low and high beam (both on at the same time). Neither the low or high clicks on the turn signal gave any light when the arm was released - only when the arm was in "transition" between the low and high.
I pulled both bulbs and the driver's side bulb glass looks a little cloudy. The filament looks a bit pitted or corroded - but neither wire coil looks broken. Which would make some sense because I could get headlights to shine when 1/2 way between low and high.
The 40 amp fuse under the hood looks good.
Does this sound like just a bad headlight bulb OR would something in the headlight switch/pull knob assembly be shorting out?
We drove up in the dark (3 o'clock AM) and one a few occasions when transitioning between low and high the headlight "faded" or "flickered", but the headlights still worked. The problem must have gotten worse or terminally ill once we shut her down for the
The air vent just below the headlight pull knob on the driver's side smelled kind of "musky or smoky" on the way up, but no smell on the way back.
Note - I have my Reese Trailer Break running directly off of the battery through a 30 amp relay so as not to draw too much power through any circuit. The only accessories I have running from my headlights are my pillar gauges. No problems with either of these in over 80k miles.
Any help would be greatly appreciated. Thanks in advance.
- Ben
- Ben
