My headlights quit working, well the low beams don't work, the high beams do work. Here's the thing; the low beams won't come on unless the tilt steering wheel is in the full highest up position. So, I guess there must be a worn wire or a fault of some sort inside the steering column? If I move the steering wheel down to where I usually set it, I have no low beams, if I move the wheel all the way up, the lows come on.
Has anyone else experienced this problem? Solutions?
