Engine/Transmission (1994 - 1998) no more air, but still running rough
2nd Gen Non-Engine/Transmission Front bumpers
2nd Gen Non-Engine/Transmission AC clutch
1998 12 valve chassis cab I changed out the fuel lines with larry b's so there should be no air in my system. Lift pump was from genos installed last january. Engine runs rough almost like it is out of balance. It has 138 k on it and valves not adjusted since 50 k, would that make it run rough? also has most everything else original so would injectors help? thanks
It is a fairly easy job to adjust the valves, and doesn't cost anything but time. Give it a shot, can't hurt. Injectors should be fine with only 138k. Take a few minutes to inspect the damper. Time might have caused the bonded rubber to deteriorate.
