I just bought Rottela T at Wally World and it has the CI+4. Very reasonable. I also looked into the Valvoline Premium Blue Classic which has the CI+4. It was available through O'Reilly's and NAPA and I'm sure others on special order in 5 gals. CI+4 is a must for our valve trains and especially for the cam lobes. I'm sure a lot of people would be surprised when and if they would pull their cams if they are NOT using the CI+4. I don't care who's cam it is,... you'd find spalling (flaking on the lobe area).
Not sure what you're saying here. WHO "has" CI-4 Plus?
The store or the oil?
A previous poster said something similar.
"says CI-4 Plus is in there" - right in the specs.
If you read the specs -carefully- and they indicate:
"CJ-4, meets API spec CI-4 Plus ... . etc. " -
it's -NOT- the "old" CI-4 Plus.
Also - check the "donut" (on gallons and quarts that has the specs).
If *CJ-4* is on there anywhere, it's the "new" forumula.
("Meets" - does *NOT* mean - "better than" - or - "as good as" !!)
Info direct from Valvoline and NAPA - has been ambiguous at best.
Bottom line - none available. Some suppliers may have old stock on hand.
However - in searching for Valvoline Premium Blue Classic (still shows on
their website) at Cummins, I talked to their main distribution center.
Guy on the phone couldn't find the (Valvoline) part number listed anymore
for 5 gal pail #V V 591839.
Pretty much what I heard from NAPA, Kragens, and a local parts store gent
who orders the store's oil. He tried - said his distributor told him it's no longer available.
Soooooo - figured I would stop by a local Cummins parts & repair facility.
Asked about the Valvoline - with Valvoline print-out in hand. Nope. Mentioned *why* I was looking for same.
He says, "I've got CI-4 Plus - Delo 400 15w-40 in 5 gal pails".
Being a non-believer (figured it's really "LE" - as they had cases of one-gallon LE
stacked on the floor) - had him trot out a 5 gal pail. .
Sure enough - *Not* LE. Looked for any CJ-4 listing, clean on that one too.
According to this parts guy - the Delo 400 CI-4 Plus was not available for quite
awhile - then just re-appeared in the system.
Maybe he's right - or, maybe it's just old stock. (Said he had 7 more 5 gal pails).
Maybe the "serious" oil users - fleets, etc. - *****ed about the CJ-4
due to more frequent oil change intervals and/or their oil analysis results ??
So - keep after it!
Check the specs.
If it says CJ-4 - no bueno!
(*UNLESS* you have a '07 or newer truck -
then some regular oil analysis is in order to determine your change intervals).
JC
