... on a 94 2wd I bought recently. I had the transmission rebuilt due to burned clutches and the VSS (sensor/connector portion not the gear portion) was replaced in the tail shaft. transmission shifts good now but no overdrive and no TC lockup. I pulled the plastic pickup gear out of the tail shaft housing and it had backed out a little and was hard to turn. I chucked the gear in my DeWalt and still got no speedo readout so I separated the sensor from the plastic gear housing and chucked up directly to the sensor tip... and got 30mph on the speedo with my drill turning max speed (1500rpm) which seemed like a slow readout for turning that fast. I pushed the gear in and felt a detent and it became much easier to turn so I thought I had my problem solved.
Now I get a speedo readout, but it is always low. Only gets to about 35mph on the interstate while I'm actually going about 60-65mph (in 3rd gear because it won't shift to OD).
I checked the orange, white/orange, and black/blue wires at the computer connection and they seemed tight so I disconnected the connector and cleaned the pins and sockets with electrical contact cleaner because of some residue on the pins.
Still no OD and speedo still reads low.
Any ideas? Trying to go anywhere on the interstate with no OD sucks down that $4/gal fuel real fast!
