No power
Just Curious!!
FASS fuel system questions
I have a 03 California model (235 hp). I am not happy with the performance of this truck. My old 460 pulled better than this does. I tow a trailer that weighs around 10k, truck just won't power up the hills. I lock out overdrive but still can't keep the rpms up. Had the ECM changed out a few weeks back, seems to be running worse since then. Originally had the flash done that seemed to work wonders but do I need to have it done again since the ecm was replaced? They said they loaded the latest program, would this have the flash incorporated?? I'm planning on installing gages soon, and also planning on some kind of box not long after. Even my wife notices the difference. Thanks. John
I would have to guess that you could add a box withpout changing much else. Get a set of gauge to keep tabs on things but the intake and exhaust systems are likely very similar to the 305hp version and should easily support a 100hp upgrade for now. To really wake it up combine the box with an exhaust and AFE intake, 350+ hp is right there for the taking :)
I was at a dyno event on Saturday. A guy had a bone stock 235 plus a TST.
A 235 should put down 190-ish at the wheels. With the TST on 4x4 or 5x5, he was at 336 to the ground before the was running out of fuel. This was with an auto and 315's.
I'm sure you would be happy with the TST on a lower setting. You can get 100 hp without too much trouble.
the module from ts performance is great and adjustable on the fly from 0 to 100 hp works great alone or with bully dog programer
