No Running Lights
Rocky Mountain TDR - Colorado Springs
Turbo Bark?
Got pulled over the other day for not having any running lights. Found the fuse blown, replaced it at pressed on. Two days latter the lights were inop again. Unfortunately I was on the road away from the house. having just installed the led clearance lights on the roof, I summized it may be coming from one of them. And since I was off the road and not going anywhere until daylight, I started to remove the trim and my accessories to get to them. Thw wiring all looked good but I diconnected them to see if iot eliminated the problem. It still blew the fuses so I was forced to take a nap until sunrise :p
After I got to my destination and finished work I decided to pull and replace all bulbs. I started on the passanger side front and worked my way around to the right rear. Wouldn't you know it... thats where I found the tail/ turn and backup bulbs corroded apart. I had to use a screwdriver and needlenose pliers to remove them. The seals are good and the lens isn't cracked. I have never noticed any standing water but did see some condensation.
Anyone else have this problem?
That's a weird coincidence. I got pulled over Friday night by a county deputy due to my passenger-side tail light and brake light both being out. Saturday morning I pulled the lens cover and discovered that bulb was black. Replaced rear bulbs on both sides with new long-life bulbs, so hopefully that takes care of it. So far it hasn't blown again. The driver's side lense does have a crack & condensation, but not the passenger side. I guess the bulb just died of old age, as there was no corrosion. I did have to replace one backup light socket last year due to corrosion, though. Try a little electrical grease inside the socket to prevent future problems.
I've also ordered LED marker lights for my dually flares to replace some of those corroded & dead OEM lights. Thankfully, the deputy was friendly and just gave me a warning to get it fixed. I think the tail lite stop was just an excuse to sniff inside the cab to see if I'd been drinking.
- Mike
I had a problem once with my running lights going out and coming back on as I was driving. With further review and diagnostics of the problem came to find that it was a wire in the trailer light assembly. Whoever did the light job on it put a plug spot in there with no resistor for the plug spot just a jump wire well the wire's guage wasn't big enough to handle the voltage and got extremely hot and kept shorting out. So we just put a bigger guage wire in there and now all is good.
Most of my electrical connections in the lights were corroded very badly. When I replaced my tailgate and fender flare marker lights with LEDs, I had to splice in 3 sets of new connectors -- the old ones would just crumble when I trid to clean them.
I've had condensation in a couple of the cab marker lights as well -- they're still going, but I bet when I take them apart, they'll self destruct! I think over the years the plastic on the lenses just gets a little warped from expansion & contraction and eventually lets in some moisture. Just one of the joys of old hardware . . .
Dave
