Guys, after doing a search I still need some help. Seems as if I remember a member having this same problem some time back but can't find the post. I've been having a somewhat hard start issue with my truck usually after it sits for some time. I assume I may need to look into the lines, but I don't think this is my problem now... . Today I changed the oil and installed a new fuel filter to see if this cured my occasional hard/rough start issue. I've owned three of these 12 valves so I'm no noob, but I'm no expert either... Kill the KDP on all three and Bombed two of them. The current truck is completely stock... . Normally, after a filter change it takes a few tries to get the truck to run, sometimes with a little press on the accelerator pedal. This truck will not start after several attempts to start it. I have opened the drain and there is a good stream of fuel coming out of it... The shutdown solenoid appears to be working properly. I cracked open the supply line at the injection pump and fuel came out but does not flow out while starting the truck... . So, I'm not getting fuel from the filter to the pump. What gives here??? Anyone point me in the right direction?? Thx TDR
