Hi all! This is my first post here, mainly because I have always been able to fix any issues with my truck.......until now. This is a 1995 with 210,000 miles on it. There seems to have been a progression to my issues or so I thought.
First Check Engine light came on. I tried the key method to diag. No helpful info there.
Next there was the Check Engine light, tach bouncing, overdrive going in and out.A friend is a Dodge diesel mechanic. He brought home OBD1 scanner. First attempt to read...no codes. 2nd attempt to read....no codes. Third attempt involved driving with the scanner in cab. The code would come in and then totally clear. The only code it showed was a high temp trans code. My friend felt that a bad ground could cause these issues. Looked at some grounds, they looked good. Changed all the cables off both batteries. Double cleaned the grounds on the engine block. Just in case replaced the Trans temp sensor (failed in the past.)
Test drove the truck about 14 miles. No issues. Stopped for about 15 mins. Started to drive home......no tach, no o/d, voltage slowly going south, no air conditioning. More research...Engine speed sensor. Makes perfect sense. Changed the ESS, went for a long drive. After 25 miles I stopped for 10 mins. 24 miles toward home, stopped again.... no issues. The last 500 feet check engine light bouncing , tach bouncing and wait to start and the rest on the right side of dash bouncing on and off. Acts as if there is a power loss then gone.
When the truck gets warmed up the issues start. Now I don't mean warm from driving. I drove it 120 miles on a Friday, no issues. Drove it home on a Sunday, no issues. Parked in front of the garage for about 1 hour....80 degrees. Started it to move it to our shop, no tach, no charging, no a/c. By the time I got it turned around and up to the shop, it had cleared up.
Started pulling the wiring harness apart. Heated the truck up so it would fail, moved the wiring harness around till we found a section that made the tach jump, checked wires could not find any issues. Just in case replaced 2 wires going to the ESS, just 18" of the wires. on the passenger side by the PCM. Checked voltage at ESS 5 volts, 8.4 volts, the ground was showing .oo6 on ohms to neg battery term. In checking that same wire from the harness at the PCM when the truck is warmed up, there is good continuity.
I have read as many posts as I can find on this type of issue and have tried to follow any clues that I see. Yesterday after the truck had cooled a bit I took it out to see if I could get the batteries charged up a bit. This is where the symptoms change a bit. Check engine light goes on and off, tach bounces around a bit, cannot lockout the overdrive. Since I had my radar detector in the cab, I noticed that the voltage would not go above 13.3 volts. I was expecting to see something around 13.9. I tried brings the rpms up to about 2000 to see if it would change, no luck. So now I am beginning to wonder if the alternator is starting to go. It is a Napa reman and is about 2 years old. The entire time I ran last weekend with no issues, the voltage was 13.6-13.7. I don't know if it matters but this started when I hauled a friends 7500 lb. trailer about 30 miles. Last year on a trip the truck started going in and out of overdrive on a trip when using the cruise control. We stopped using the cruise control, no more issues on that trip.
I realize this is a long post but I think it helps if I give all the issues and their order.
Thanks so much.
Thanks so much.
