Here is a good one , the throttle quits responding on my 99 24 Valve, the CHECK ENGINE light comes on, then after i try to accelerate again, there is nothing until I depress the pedal twice, then it responds again. If it runs throuogh 4 start cycles the CHECK ENGINE light goes off until it does it again.
I took it into the local dealer to check the code and got the following Codes P1639,P1682,P0500,P0122,P01765,P0121 and P1693. What does allthis mean and is there a simple fix?? I'm inclined to believe that it could be a throttle sensor?? Anyhelp would be appreciated.
Thanks Terry
Thanks Terry
