In 01 when I did the repower on my Scout I discovered that there was no previous attempt by the factory at sound deadening. The 4BT I had installed was as loud inside as it was outside. I did not take any db reading for baseline but I did last week for the baseline from now on. I had previously installed Accumat on the inside of the firewall and got the noise reduction down to a driveable level. The sound level measured was 87db on the A scale at 65 mph, windows up. Out side at idle I measured at 3' up and 3' from the Scout at the front axle and in front. The readiings I got were 85db, A scale on both sides and 88 db in front. My goal is 75db which is what I measured inside my wife's 94 Dodge Ram CTD. To day I took second measurement after applying QuietCar and I dropped 1db all around the outside and inside windows up at 65 mph I measured 84bd (A scale). That's a 3db reduction and I only coated the transmission tunel access, a panel that measures 12" X 18", the cowl area at the base of the windshield and I also covered the oil pan. The cowl has a 1. 5mm coat and the other have about a 1mm coat. Maximum coat thickness required is 3mm.
As soon as I can I'll coat more of the Scout and let you know the outcome.
All I can say is this stuff is great!
Steve
Steve
