... I HEARD THAT... !!!
Ok, the "manual" says the VE is good with PSI as low as 3psi... ya right !!!! what do they know... see they weren't thinking of that pressure applying to a 3K RPM run... I don't know were their heads were at... . errrr, maybe I do. .
Ok, if you have a stable supply at 8-10psi then even at WOT (3450 engine RPM... I got it right this time. . ) the VE will do it's job...
We ran the supply pressure for fits and giggles, up as high as 18-20psi on the stand. No difference was noted in the pump performance. There is a drop in CC/1000 as you go up in the RPM band which I feel is governor related. While there was some discrepancy between a "test pump" and my personal "on truck" pump, they both exhibit similar behaviour to a degree. .
Because were running the thing up to very high RPM's we didn't deliberately reduce the supply pressures to cause possible failure or damage. It was a test to determine, among a bunch of other things, supply side variations and/or results from higher supply pressures on the VE.
I've also come to learn that the operating pressure of the VE needs to be corrected a bit... they will run from 4,000 PSI to as much as 10,000 PSI.
I have no physical, test bench, numbers to prove it to you, only info from manual(s) and other experienced persons.
Pastor Bob... .
