Ok, Not sure what are normal transmission Temps for a re48. The Transmission is built with extra clutches, shift kit/updated valve body, a triple lock converter and a bunch of billet parts and a deep transmission pan the holds 6 more quarts of transmission fluid. My pan temp gauge reads 180-190 degrees and the Edge reads 225-230 degrees when towing about 15k lbs around town and about 20 degrees lower at highway speeds with Overdrive. Anyone have an idea where I should be? the Edge temp readings worry me.
I also just ordered a BD dual layer trans cooler with a 800cfm fan, has anyone installed one before and where is the best place to put it?
Thanks
Kyle
Thanks
Kyle
