Some people have good luck, some dont. I was one that didnt have good luck. Bought a set of the Jammer 4 nozzels. Had them swapped and pop tested by a local diesel shop. Checked out fine. After I installed them, I had a slight stumble at idle. Under throttle, it was fine, but it idled funny, almost like it had a semi agressive cam in it. after a couple months, I got sick of it. Pulled them out and put a set of full Sheids 90HP injectors in and the problem is gone. The thing is, most shops can pop test an injecotr, but almost none of them can flow test them. Most likely one of my injector bodies was fine at the stock level tip, but the oversized Jammer didnt play to well with it. Thats just my experiance.
