2nd Gen Non-Engine/Transmission Numbers on lower ball joint?
2nd Gen Non-Engine/Transmission front end parts
Ok the ball joints I got from NAPA have numbers on them. The lower ones do anyway. 0, 1, 2, and 5. On all 4 corners. I assume this is to adjust caster/camber? But on my old joints that I pulled out I don't see any numbers. They are however really rusty. And I see no marks on the axle housing. Anyone know where I should put these numbers?
Also when I pulled them out I pulled the top first and then the bottom. I assume when installing new ones I should do the reverse? Bottom then top?
BTW the pressing out the hub trick using the power steering worked like a champ! Not sure how long this would've taken without that tip that I read about on here! That and PB blaster seems to work really well on rust! Read that on here too!
