Re: Update 12/28
Would you do it again?
Originally posted by Kirwin
Well I have nearly 300 miles on it now. The trick to find reverse is to not allow the transmission to stop. Either by getting into reverse while the truck is still moving or if I have stopped and it won't go in, release the shift lever, let the clutch out to spin the transmission, and then try again. The transmission is still quite stiff but it is getting better. You definitely can't speed shift through 3rd and 4th. The synchronizers are very stiff and will frequently not allow the gears to align and drop in. Especially cold. This can be embarrassing as everyone else is accelerating from the red light and I moving after starting out in second, but can't get it into 3rd! Sometimes the same thing happens in 4th. 5th and 6th are easy though. They seem to always drop right in. I'll keep you posted. Ken Irwin
