Matt42
I'm not sure that this is the right category, as the NV 4500 transmission that packed it in was on a '98 Chevy K20 6. 5 turbodiesel. But here goes anyway.
On Wednesday, 9/26 we were southbound climbing Lost Trail Pass in Montana, with a fully loaded truck and 3 ton equipment trailer. There, the last of the Syntorq oil in the Chevy's NV 4500 leaked past the defective seal into the transfer case. The transmission then did what you would expect with a GCVW of 14K on a 7% upgrade. The resulting noise was very much like exhaust on a 350 V8 at full throttle. The brake fluid in the clutch line boiled, and the clutch faded. We discovered the faded clutch while trying to shift into 4th at the summit. At that point, the transmission jumped gear and killed the engine.
(I need to mention that our Tempe, AZ based satellite phone service provider had *allegedly* damaged our Iridium phone, so we were SOL for getting help, as the phone was in the phone hospital. )
Once the clutch cooled, and the engine electronics rebooted, we determined that we could still move, but with considerable noise. Salmon, ID, was 45 miles of downhill and flat, so we limped in. Quality Motors in Salmon was able to get right on it. Disassembly revealed a damaged input shaft and countershaft, with most gear teeth chipped. The input shaft and bearing had overheated, melting the plastic bearing roller sleeves. They had a new transmission overnighted in by Friday morning. Bob and Jeff at Quality Motors are super people!!
That's twice for this truck, both on various parts of US 93. The first was a parting of the engine oil cooler line, which resulted in a complete disabling. Chevy drivers: Any clues as to what goes out next? It has 24,000 miles on it. My boss is now VERY upset for going low bid and not getting the Dodge.
Matt in AZ
Matt in AZ
