NV-5600 on ebay
New short block or low mileage?
Red Line 85+ Fuel Additive - cheap supplier?
I know the front driveshaft needs to be 6" longer and the rear driveshaft needs to be 6" shorter. I think the crossmember is the same, and the clutch, this is an '02 so it has the 1 3/8" input shaft. I think they use the same bellhousing as the 5-speed and I knoe the t-case is the same.
You my want to make sure it came off a 2wd or 4wd truck. the tail end of the housing are different on a NV5600. I learned that when I swaped out my 5 speed.
I think the seller will be in for a shock we he goes to ups it for $30. 00(if it's not over their weight limit)
Bob
That is a 4x2 transmission. I just compared it to the pictures I have of mine...
The patriot, I converted my '98 and it was easy. See my mods page here for info and pictures of my conversion.
I saw the shipping for $30 too. I know one of the cheapest methods goes the wrong way around the world on a pallet and still costs a flat rate of $150 to the lower 48.
Looks like he just changed his way of shipping,probably found out it'll cost more then what he gets for it!!! :eek:
I just ordered a transmission and it cost $108 to ship it from LA to Seattle. Got to me in 3 days. I should look at the freight label.
Hey Guys, any idea what that tail housing for a 4X4 would cost? Is it available??? I'm the "current high bidder" on that trans, forgot to look closer!! I'm overseas and can't call the Dealer
Thanks Tom
2001 2500 4X4 5-Speed Longbed DD TTPM, 4" pipe, AFE Tow Rig
Just talked to Dan at Quad 4X4 in Montana, seems I have to change the mainshaft also, jut like I thought, and he has all the stuff. Shouldn't cost a whole lot (I hope) Give me a chance to go through it anyway! And what better time to upgrade the clutch!!
