I have a '01 2wd truck with a nv5600 transmission. When I refilled the transmission, I was unable to get the complete nine pints of oil in the transmission. The latest TDR magazine indicated that the fluid level should be at the top of the fill hole or higher. With the transmission installed like it is [rear end lower than the front end], how much total oil should I be putting in the transmission? Getting more fluid in the transmission is do-able if I jack up the left side of the truck up. I am concerned about filling the transmission so full that the front seal leaks and oils the clutch.
I am currently getting a chattering noise when starting from a stop in second gear or at low rpm in third gear and I am wondering if this due to lack of lubricant to the front of the transmission case.
Thank you for any help you can give.
Dean Jager
-- email address removed --
Dean Jager
