Engine/Transmission (1998.5 - 2002) nv241 vs. np205
The NP205 is all gears with a cast iron case, low range is 2-1 ratio. Also in the Dodge and Chevy application is was used with a right hand front differential.
The NV241 has a chain for the front drive, aluminum case and 2. 7-1 low range ratio, left hand front differential.
"NICK"
THenningsen,
The 205 is very heavy compared to the 241 and has a 2:1 vs 2. 7:1 gear reduction. I guess Dodge considered the 205 overkill for our trucks, and as not to many have "grenaded" their T-Case, their probably right. The gear reduction (although probably acceptable behind a Diesel) was a bit underrated (in my opinion) behind a gas engine. The NP 208, NP (NVG) 241, and now NP (NVG) 271 are steps in the right direction for most of us. For those serious rock crawlers/ 4x4er's the Atlas II or a twin stick dual T-Case setup is the way to go.
Just my opinion.
Ron
