Engine/Transmission (1994 - 1998) NV4500 5th Gear Gone, whos reman to buy?
2nd Gen Non-Engine/Transmission Arlington Texas area?
Engine/Transmission (1998.5 - 2002) Fuel Pressure Isolator?
Bought a 96 5spd 12V 2WD last week in Baton Rouge.
Hooked a trailer to it and starting towing my 98 home. Halfway through MO we lost 5th gear.
Got it in the shop and had a new updated 5th gear nut sent. Turns out it was already fixed. . Several times apparently.
The splines are completely stripped and you can turn the gear on the shaft easily.
Whos Reman should I get?
Standard Trans or Blumenthals?
I plan on getting a Con Ofe Clutch with the larger flywheel, along with a 1 3/8" shaft.
This truck is a TOW vehicle mainly. . I only want to do this once.
I've read up on Quad's stuff and it sure is $$$$$ pricey. . does the fully splined main shaft cure most 5th gear issues?
Thanks in advance.
Give Scheid a call. Just got mine from them, no fully splined mainshaft, but did have all the updates. Haisley does the transmissions for Scheid. Decent price.
Ryan
I have Quad 4X4's Torque King main shaft in a new NV4500 transmission. It was put in exactly 1 year ago and no problems, even towing in 5th.
For me, it was worth the extra expense due to the power upgrades I have.
If you were a stock or "almost" stock and pulled a heavy camper, I just say get a regular new or rebuilt 4500. But with the mods you have you can be assured you'll be looking for something quite stout ... and a rebuild uses the same old tired gear on a new main shaft.
If your planning on keeping the truck for a few more years, you may want to give Dan the Gear Man a call at Quad 4X4.
I won't be modding the 96 to the level of my 98 12valve...
We're looking at between 375 & 400HP. . Just to tow my truck to pulls etc.
jwilliams3 said:
Garrett,
Type in nv4500 on ebay.
I found like 4 or 5 2wd versions for like $800 no core.
Justin, I tried that. Thanks for the suggestion, but
I don't want to buy something that I'll be tearing out to fix 5th gear half way through next years sled pulling season.
standard transmission has a decent deal on their fully splined mainshaft kit. I believe its less than $300. Or the entire transmission rebuild kit is $600. They might be able build one up for you too.
