I recently installed the TST #11 plate and am really impressed by the difference in performance. Unfortunately, I found out all too quickly that the stock clutch is now the limiting factor. Done some research using this site & the many clutch-related posts have been really helpful - maybe a So. Bend in my future?? - any recommendations would be much appreciated. My truck is a daily-driver, so besides AFC spring, I will likely upgrade only exhaust & turbine housing in the future.
If anyone has done a clutch swap, what I am trying to learn is, do I need a special tool to separate the shifter extension from the base?? My shop manual indicates this to be a press-fit & shows a special tool - is there a trick someone has used?? Are there any other "gotchas" I should be aware of??
I am new to this group & am really impressed with it. Thanks all...
Mike T.
98 2500 4x4 12v/5sp,QC,SLT,SWB
Flame Red, 72K at 03/01, 4. 10s, 35-inch BFGs on Welds, mild lift.
K&N, TST #11, DiPricol boost+pyro (more to follow after clutch infusion)
"when the going gets wierd, the wierd turn pro" - H. S. T
Mike T.
