Archived NV4500 dieing near Ogden, UT
Archived Comp Edge install help needed asap.
Archived charging trouble
GAmes
I sure could use a recommendation for a good trans repair shop in the area. 1st, 2nd, 3rd and 5th gears all make noise when engaged. Trans still shifts smoothly and the clutch is normal. I'm pretty sure I am in need of a set of cluster gears. The trans has about 150k on it since Standard trans installed the fully splined 5th gear kit. If someone can't give me a recommendation for a shop that they have had work done in I will drive back to Tx in 4th gear with my fingers crossed before I will do eeny, meeny, miny, moe in the local yellow pages.
I'm in a library making this post and they are closed on Sun so I may not be able to respond until Mon.
TIA
Gary
ogden repair
Sorry to hear that you are having problems on your trip.
Call Ken Jones, he is located in west Ogden.
801-791-2328 or 801-731-6291. he is also Diesel Dynamics. If he can not do the trans, maybe he can steer you to someone who can do it. He does quality work.
hope this helps.
Marv.
Thanks Marv,
Ken bent over backward to help me out but there wasn't a trans anywhere in the area and having one shipped from Ft. Worth wasn't cost effective. I babied the first three gears and drove to Tx in 4th. With the top off the only obvious damage was a flat synchronizer and I didn't stick around for the rest of the teardown. I'll find out the total damage tomorrow and hopefully will be back on the road in the afternoon.
I will keep Ken's number on file though. He is a top notch guy.
Gary
