Engine/Transmission (1994 - 1998) NV4500 from gas same as diesel???
Can a 4wd NV4500 from a 3500 cab and chassis with a 360 gas engine be swapped out to go behind a diesel or is the input shafts different? bellhousings?
There are 2 NV4500 transmissions. An LD and an HD. The HD is used behind the V10 and diesel. The LD is used behind the other gas engines. It wold be worth looking to see which one it is. Bell housings are different between the engines. Not sure of all of the input shafts.
here are some quick specs. I just installed one in a first Gen. last weekend.
NV4500 GM (6. 34) GM (5. 61) Dodge Dodge HD
Main case 12. 375" 12. 375" 12. 375" 12. 375"
4WD Adapter Housing8. 125 8. 125 6. 25 6. 25
2WD Tailhousing 6" Tailhousing 6" Tailhousing 13" Tailhousing 13" Tailhousing
Yoke Fixed Yoke Fixed Yoke 30 spl Slip yoke 31 spl Slip yoke
Input shaft stickout 6. 625 6. 625 7. 625 7. 625
Input shaft spline 1. 125" 10spl 1. 125" 10spl 1. 125" 10spl 1. 250" 10spl
Pilot Dia . 590" . 590" . 750" . 750"
Dodge NV4500 All V-6 & V-8 gas motors including the HEMI have 1 1/8 input shafts. V-10 & Cummin's have 1 1/4 input shafts.
