nv4500 oil change
Bugscreen
transmission quick fix?
Changed the oil in my trans for the first time today at 82000 miles. Used the bottom pto cover bolt for a drain, noticeing there is alot of transmission below the level of this bolt. I don't think I got all the oil out of the transmission because when refilling it it did not take a whole gallon, had about 15 to 20 oz left. There is a nice looking boss on the end of the transmission that looks like if the drain were there it would drain the whole thing, go figure. Anybody else run into this?
If you filled it to the bottom of the fill plug you should be fine. When I changed mine at 30K, I actually removed both PTO plates and painted the rusting metal. DC was too cheap to pay NV to paint these I guess.
When I had the PTO plates off, I used paper towels (Scott blue ones) that absorb oil to clean the bottom of the casing.
Even then, I think the fill was just slightly less than 4 quarts.
I changed mine a few weeks ago at about 68k plus and decided to pull the PTO cover just to see how things looked in there. I could see that there was no way all the oil could come out so I used a suction gun and sucked it all out that way. I was able to get all 4 quarts in.
Mark
Red '98 12valve 2500 4X4 Quad Cab, Long Bed, SLT, 5-spd Manual, 3. 54, Dana 80 Rear,Camper/Tow pkg, 33x12. 50x16. 5, Rancho RS9000 shocks, straight piped, silencer ring hanging in shop, Yet to be Bombed, 69K+ miles.
Ya, Ifilled the transmission to overflowing, When first got truck painted all the parts they didn't paint, d shaft,front end, transmission. My truck is white, But underneath the cab and bed it is semi-gloss primer gray. Weird huh? I'll change transmission oil again at 100k and get it all out, good thing I ordered 2 gals. Thanks
I noticed this when changing my fluid last month. I jacked up the the rear of the vehicle as far as it would go w/ my floor jack & got a lot more lube out of that transmission.
Mike
94 2500HD 5sp 4. 10LSD 4X4 RWAL w/GearVendor OD, K&N Oval w/ Pre-Filter, Straight Exhaust, Geno's Fumotovalve, AW-Direct Idle Controller, DiPricol Boost/Pyro/Fuel, Mag-Hytec Rear, 124K miles. Halon Protected, NRA Member. V1.
I always remove PTO cover,and as some one said jack up / or on two stagered 2x4's (about right to get the grease to flow forewards--blot out the bottom of the case. Last but not least-- I remove the 4 " magent (from speaker) that i attached to the out side of the PTO coverwhen new,(low cost item)wash of cover ,silly cone,and re install. Catches anything the factory might have missed And other than your lube sample from you lab will let you know if you might want to look deeper!
Works great on the rear end cover also.
Install in stages,the little one might get wise if both her stero speakers go out at the same time!!!!
96-3500 SLT EXT. CAB AM/FM/CD-RINO LINER. D-CELERATOR EXH. BRK-RED LINE VAC. OVER HYD BRK CONTROL- AIR BAGS W/HVY DUTY AIR COMP. PUTCO S/STEEL DEEPBOARDS FRONT TO REAR. REESE 20K 5TH WHEEL & GOOSE -REESE 20K HITCH BELOW W/17K RECEVER. CLEAR COATED & SOUND DEADINGING &UNDER COATED 5 SPD/W 4:10 MCHLN'S 235/16'S UNIDEN PC76/WEATHER-WILSON 1000 MAG MOUNT ANT. 4 WHL ANTI LOC BRK SYS.
750,000 miles
