NV4500 OIL Survey--Need ALL Members!!!
NV4500 OIL SURVEY RESULTS
Dash Protection?
Factory untill 25k Amsoil series 2000
now in for 35k
No problems
1996 4x4 3500 4. 10 5spd, Diesel Dynamics stage 2 injectors, #5 TST plate, Govoner spring kit, Ported Head, ATS manifold Jet-Hot coated, 16cm2 housing Jet-hot coated with 4" exhaust, Cummins exhaust brake, US Gear overdrive, Grover air horns and Mag-Hytec rearend cover
[This message has been edited by BPINE (edited 02-08-2001). ]
Amsoil Series 2000 75/90 for 4500 miles. .
Rick
RICK
97 2500,CC,5 SPEED, 3. 54 Limited Slip,Psychotty System,K&N, Pre-Turbo ISSPRO 3" Pyrometer & Boost Guage,Silencer Ring Removed
12,000 RBW 5th Wheel Hitch,25' Excel 5th Wheel,Rancho RSX17000 Shocks,Amsoil Dealer,Straight Piped
factory fill
31,000 miles
no problems
96 2500 4X4, SC,SLT, 12 valve,lost kitty 5SP 3. 54. line-x liner All stock (for now)
[This message has been edited by ROCKYMNT (edited 02-08-2001). ]
Factory fill til 26,000 yes/no. . MAYBE
Amsoil Series 2000 75w-90- 62,000 NO
Gene
1997 Cummins Dodge 4x4 Bombed & Amsoiled. Amsoil Premiere Direct Jobber, Member of: NRA Business Alliance, GLTDR, WANTED: Wrecked Dodges.
www.awdist.com
Awwww, Gene, ya didn't tell them you make 700 hp and powershifted to third. #ad
I don't call that oil-related #ad
Missing a gear is hard to blame on oil #ad
Couldn't resist this, Gene has been getting in too many on me lately #ad
Lets see what Dave Mitchell/Enterprise Engines finds when they pull his 4500 apart next week #ad
Vibration in 4th is most likely NOT oil related. Few bearings are involved because power is not going through the countergear (cluster), just straight through the mainshaft. Also, we all know how much the Cummins vibrates under load at low rpm--that alone can lead to transmission problems and no oil can prevent it.
1. Factory fill ,2. 45,000 miles, 3. No problems
Rattlin' Randy J 1999 Quad-Cab, 2500, 5-Speed, 4x4, Short-Bed, Rhinolined,
Limited Slip, Tow Package, Camper Special,K&N filter, staight exhaust with 5 inch
chrome tip,diamond tread alu. tool box ,Centerline Rattler wheels with 285-75 BFG's,Also 1971 Convertible Barracuda Tored
340 4-Speed
1) The product used; Factory fill
2) Miles obtained so far. 35,000
3) Any oil related problems: NO
George, Perry County, PA
99 3500, Reg Cab, 4x4, NV4500, ISB, 4:10,VA box,Putco Boss
running boards, Grover air horns, Intense Blue.
95 4x4 2500, 93000 total miles
changed to Torco Full Syn 75w. 90 @ 26k
and again at 50k and will likely go with syntorq the next time (GL4 vs GL5).
No problems to date. Oil analysis shows all is well.
1) Castrol SYNTORQ LT
2) 68K (changed once @ 40K)
3) No problem
Note: Big difference between SYNTORQ and Syntech
[This message has been edited by gooded (edited 02-08-2001). ]
1994 1st 30,000 miles factory fill.
Remainder up till I sold it at 122,000 miles Mobil 1 GL5, no problems. My brother has it now.
assume factory filled.
106000 miles
no
97 3500 SLT REDext cab duelly p/u 5sp 3:54 2wd 245/75R16
3" straight exhaust stock torque plate slid full foward star wheel tweeked
105,000 miles still with plenty of ZOOM... ZOOM... ZOOM
RON Z
Orginal Trans:
1. Amsoil S2K 75W90
2. 150,000 four changes, lost 5th gear three times, took out mainshaft last time. Sold trans to rebuild shop. NO OIL Related wear.
3. NO
Factory New (99 Model) replacement NVG4500:
1. Factory oil
2. 26,000 (no wear or problems with sample tested but only 30W oil. NVG5600 Oil???)
3. No, but ****s like sh?t.
Just Switched to Amsoil S2K 75W90 and trans shifts better.
jjw
ND
Factory fill drained @ 25k- refilled with Amsoil Series 2000 75W-90 & Geno's filter kit installed. Serviced again @ 50k, again with Amsoil. Currently 60k- no problems.
Bill Lins Wharton, TX 98 2500 QC SLT,12 (the CORRECT # of)valves,NV4500,3. 54 LSD,Manik grille guard,Semi-Psychotty Air,Amsoil everywhere, Reading aluminum utility body and bumper,Optima yellow tops- silencer ring & muffler stolen.
