NV4500 OIL Survey--Need ALL Members!!!
NV4500 OIL SURVEY RESULTS
Dash Protection?
Factory Fill 32K
Noticeable buildup in transmission
Royal Purple MaxGear 75W90 for last 87K
Noticeable smoother shifting
on 96 215 hp model.
89 350 5 spd,
Royal Purple MaxGear 75W90 from 70K to 170K
OEM til 70K
Made the 'Getrag' last and shift smoothly.
David
1) Factory Fill
2) 12000 miles
3) No
1999 QC, 4x4, 5speed, Every option, Signal mirrors, K&N Air Filter, Rhino lined and Gooseneck hitch
I changed from OEM at 128,000. Now use Amsoil Series 2000 at 188,455, love it. Keep check with the MagHytec dip stick. No wear.
Preston
96 3500, Black SLT, 5 speed, turbo diesel, , with US Gear overdrive, Rhino liner, Reese 15,000 lb. fifth wheel hitch, US Gear de-celarator exhaust brake, muffler elimination kit, Amsoil lub. , Mag-hytec rear cover, dual-remote by-pass filters, and Roadmaster Active system, AutoMeter Pyro & boost, Primeloc
Mopar lube changed at 50,000, refilled with Mopar.
70,000 on now.
No problem so far.
Paul A. Schmidt
95, 4X4, SLT 2500, 5 spd. , 4. 10, 270 hp. ,675ft. lb. TST, AFC spring kit,215hp. injectors,16cm2 turbo housing, Pacbrake, Walker muffler,
GearVendor O. D. , CenterForce Dual Friction clutch.
Eastern PA.
amsoil
30000 miles aprox
I'm getting rattling and buzzing transmitted thru the shifter about half the time.
'99 3500 Quadcab Laramie SLT with customized aluminum flatbed
B&D bombed with Jakebrake, firestone air bags
5 speed,4X4, truck mirrors, trailer towing, and camper pkgs.
20,000 lb. trailor hitch
Ranger Cb with Messenger kicker
Amsoiled throughout. . .
Factory fill
65,000 miles
No
Amsoil Series 2000 75-140
20,000 additional miles
No
98 QC 3500 4X2 ISB 5-speed; 10-level Competition PowerMax; DD Stage II's; 4" exhaust turbo to tip; Luk ProGold; K&N; Amsoiled; Pillar Mounted Boost & Pyro; etc. , etc. ,
Factory fill
65,000
No problems
Keith
'98 2500 QC SLT+ LWB,12v, 5 speed, black, 3. 54, Warn winch & brush guard, PIAA chrome 520's,diamond truck box, stainless rockerpanels,diamond bed rails, spray in bedliner, hitch reciever, 33 BFG MT's, Reese 5th wheel hitch, Banks Stinger Plus, pillar mount boost & EGT,muffler & TSR gone, Uniden CB
Komfort 26' 5th wheel
'99 Durango
-120,000 miles
-factory fill
-No problems, a little stiff going into gear when really cold. (Changing to Amsoil 2000 75-90)
97 2500 Reg cab 4WD, Emerald Green and Driftwood, 3. 54 gears, 2" Daystar Coil Spacers, 315/75/16 AT BFG'S on Alcoa's, Trailmaster SSV shocks & SSV steering stabilizer, K&N, stock, oh yeah--no silencer ring
K. Kinion
Factory Fill/30000 miles/No Problems
1999 24V 2500 HD,5 Spd, Luverne Steps, Predator Topper, Unbombed (yet)
1995 Impala SS, Dark Cherry Metallic
1995 Dutchmen 26 foot travel trailer (the reason for the diesel!!)
1997 Honda Shadow ACE 1100
Factory fill
64K Miles
No problems.
Eric
98 Quad cab 4X4 2500 12 valve,5 speed,3. 54 rears, 8' bed. Michelin 275 75 16 lr-E. Boost and egt gauges but basicly stock except for a "properly adjusted" AFC. Cat in the garage. Uniden HR 2510, Texas Star 1200 amp. 63,000 Mi as of 1/27/01.
NRA life member. High power/IDPA.
Had 300K on my 96 when traded, changed to Amsoil Series 2 75/90 at 20K.
5th gr. nut came off twice, last time had it spot welded on. Changed lube when nut came off, don't rem. miles.
No problems.
These were hard used miles too, w/GV splitter w/same lube in it.
Factory Fill till 35K, changed stayed with Mopar currently 47K, no problems. However, I do have a viberation sound in 5th when towing at regular rpms, (60 to 72mph)is this fifth gear going south or is this normal or the clutch? Suggestions? Thx.
Idg
From what I've read on this site, that very well could be the 1st symptom of the 5th gear starting to back off. Apparently it 1st gets cocked on the shaft & then backs off as it pushes the nut off. There is a TON of info here on this. . Do a search & you'll be swamped w/ info. Good Luck!
42k miles on factory oil
5th gear went out, but that's not an oil problem.
Dealership performed repair and refilled trans.
Now 75k miles with no problem.
