My NV5600 has started having a problem with gear clash (grinding) when shifting from 5th to 6th. It shifts fine through all the other gears and into reverse. I have a releatively new SBC 13" clutch. It was doing this some prior to changing the clutch but is worse now. When I changed the fluid about 40K miles back I used Penzoil Syncromesh and added 6 ounces of Limited Slip additive. I am going to change the fluid soon and not put the additive back in. Has anyone else had problems with 5th to 6th gear?
