JGrover, I'm running 4. 10 gears so when I hit 4th over the rpms start to go up fairly quickly at freeway speeds. I'm seriously thinking of changing the gears to 3. 54 or 3. 73 to help, but then 5th over would be pretty high. I see your RPM is pretty low in 5th over with the 3. 54 gears. I'm already to high geared in 5th over except for extremely flat running.
I'm one of those that hates to alter stock things, so I'm reluctant to change plates etc. With stock I don't have to worry about excess EGT's etc or popping a head gasket etc. Paranoid? Probably LOL.
Do you know if the GV is or isn't approved for use with a exhaust brake? I'm running one and it seems to work fine, but that could be a disaster waiting to happen if it isn't designed for it.
I had thought the NV5600 would be a good trans choice but with parts getting hard to get, it wouldn't be a good idea it seems. I doubt very much the previous owner of my truck fixed the 5th gear nut, so is there any warning, i. e. sounds or anything?
Thanks
