rbattelle
( FYI - friction modifier reduces friction)![]()
I'm not so sure of that. Can you cite some reference that discusses this?
Ryan
Yep. My '01 had a sticker right on the transmission listing the Texaco #... something like 1874 or somehting like that. I couldn't find any info on it anywhere so I ended up order a synthetic manual transmission fluid from the mobile guy... a straight 50 weight. Ran that for about 30-35K before I sold the truck. Didn't find out until I was ready to change the fluid in the then new '04. 5 that I "shouldn't" have been running it. Shifted fine and didn't make any odd noises or anything. I still have over 3 gallons of it here that I'm now afraid to use.They told me it was a fluid made by Texaco.
I used Blackstone to determine the oil had sheared, so yes, I have a UOA to back up my statements (to keep the Amsoil crowd from flaming me). I installed the Amsoil/Fast Coolers in October, right before my trip to Key West (with the slide in). The oil had one trip to New Mexico also. Roughly 10k later, I noticed the shifting was going downhill.
So I pulled a sample and, while everything looked good as far as wear, the oil had sheared some... and that is what I was told was causing my shifting to deteriorate.
steved
Steve,
I thought when I read your report from Blackstone on your Amsoil MTF it came back in excellent shape, as they reported wear was very low (Iron was 12, and universal averages for Iron is 88), and they were not sure why you needed to change the oil to make it shift smoother. The Viscosity was 54. 2 SUS@210 F*, which is perfect.
They reported, "There was a "trace" of insolubles, but was not a problem. "
As I recall they said the "universal Averages" were based on 19,700 miles, and yours only had 10,143 miles.
Question,
I changed the oil in the transmission about 6 months ago (about 9K on this oil change) with Pennzoil Synchromesh isn't that the correct oil to use? My I have 42K on my truck and when the truck is cold it will grind going into 3rd. My dealer (not by choice, I have to go there because of my ext. warranty company) says the only other oil to use is some castrol transmission oil.
I take very good care of my trucks, so I feel they are jerking me around.
The dealer says if it does become a problem they might not cover it because of the oil I used.
thanks, Andre
And if you read further, the viscosity had changed from what a virgin sample of MTF should be. IIRC, the group at BITOG indicated it had thinned down to around the consistancy of RP Synchromax (for camparison only)... and my transmission didn't like RP Synchromax. Therefore, with the information I had, the consensus was MY nv5600 doesn't like thinner fluids and there was NO explaination why my fluid had sheared (coming from SEVERAL amsoil dealers).
I made no mention of high wear metals, did I???? I said it had sheared. Please do not try to twist things around. IF you want to answer my shearing question, please do. But low wear metals mean nothing to me if the transmission won't shift... no matter how "great" the fluid is claimed to be.
steved
Steve,
With due respect to you and BITOG, when oil "shears" it means permanent viscosity loss, and will never return to what it once was. The report I read said the Viscosity was 54. 2 SUS@210F*, which converts to 9 cSt@210C*. Here is a link to convert:
http://63.111.59.207/Uniqema_Compressorinternet/ProdCat/ProductSearch/Cst_to_Sus_Converter.html
The Amsoil MTF out of the bottle has a Viscosity of 9. 6 cSt@100C*, which meets the Manufacturers specs.
The Chrysler specification is MS 9224 & 9417 (Synchromesh fluid) and the min oil viscosity is 8. 0 cSt when new. The min viscosity after shear is 6. 0.
The AMSOIL MTF is 9. 6 cSt@100C*, which is well within the parameters listed by the mfg for the application. Although this fluid is listed as a 5W-30 it is not a motor oil and does not follow the same viscosity requirements. What I mean by this is that Chrysler & GM wanted a specific viscosity which fell between a 20 and 30 grade combined with the cold temperature properties which is why it meets the 5W rating.
My NV-5600 was getting a bit harder to shift as well, and it turnd out to be the "pilot" bearing for the clutch, as it was binding and allowing the transmission input shaft to turn, making it difficult to shift. Since your truck has more than 100,000 miles, you may be experiencing this same thing.
Hope you get to the bottom of your problem.
Wayne
amsoilman
Steve,
