Hi,
I had the clutch kit replaced on my 2004.5 stock 5.9 cummins 2wd with NV5600 replaced today. I replaced it with a Luk that I purchased from RockAuto. Now, with the truck idling, I'm unable to shift to 1st gear or reverse gear. The installer thinks it is an issue with the Luk pressure plate and that I should complain to RockAuto. Before I do that I wanted to post the issue here and see if someone can provide some insight.
A couple of observations that I've made are as follows:
- With the truck turned off, I am able to shift to 1st and reverse gear without any issues
- Shifting through all the other gears (2-6) are smooth. The clutch release is smooth.
I have a guess as to what the problem could be. The videos that I watched on youtube directed one to put some grease on the input shaft spline. I suspect that this is to allow the clutch plate to slide away from the flywheel more easily when the clutch pedal is pressed in. The installer may have forgotten that step. My suspicion is that the new clutch plate is still slightly touching the flywheel and turning the transmission thus causing my issue.
Any ideas of what the problem could be and what I can possibly do to remediate it would be greatly appreciated.
Thank you in advance.
Truck details: 2004.5 Dodge Ram 2500, 2wd, NV5600, 187,500 miles, stock except replacement of original injectors with remanufactured ones from Geno's (appears to have increased horsepower as I lost around 4-5 mpg after replacement).
