while towing you should not let the rpm's drop below 2k unless you are on level terrain. With a stock auto that means about 3k in direct at 75 accelerating or pulling hills or 2k cruising in od. Real nasty gear split. Under load below 2k,tc locked up, your lock up clutch fluid pressure is low and clutch slippage or shudder can / will occur which will require a non warranty overhaul/ DTT upgrade. I tow a lot and that is the reason for my GV overdrive unit. I tow in direct, GV od, about 2200 rpm @75 mph locked up and 2400 rpm unlocked. The GV puts me about 250 rpm higher than in 4th ( od locked up) or the same as 4th unlocked w/ DTT 91% tc. I prefer the direct-GV od as that part of the trans is a little stouter than the collaged afterthought od part of the trans.
MY $. 02
