~O.K O.K I Give How Do I Kill The 85 MPH Speed Govener?~
some info on the lift pump
SPEEDS ON A 3500 WITH 4:10 REAR?
had my 01 eth to 90 with 353's could have gone faster but a honda flew by me and the smokey got him instead so I lifted #ad
sounds like the abs wheel sensor is triping the overspeed/defuel sensor thus the defueling- someone told me which wire to snip but I can't remember #ad
Sorry
P. S. -- check post 99 VS 2001 - they have a solution
*Won Ton* 01 3500 eth 6spd- ez, pacbrake,practical solutions idler,MBII cb mount, bombed texas ranger CB,wilson 5000 cb antenna,weathertech visors,ultra boards, pace edwards roll cover, rbw little rocker, rhino liner,& NWC-TDR hitchplug,Mud flap,& More to come
*Pull Toys* y2k Cardinal 29rlb-lx, 175w solar panels, 1. 5kw trace inverter, dish net sat, colman fire pit
[This message has been edited by dabubba (edited 04-15-2001). ]
My 2500 with 4:10s would go 100 before the tire swap. Now about 110.
1998. 5 2500, 4x4, SB, Red Sport, Agate Interior, Quad Cab, O. H. Console, Auto, 4. 10 LSD, Trailer Tow and Camper Special Packages, Mopar Aluminum Nerf Bars, Spray In Bedliner, Pioneer/Jensen System, 255/85's, Bd Adjustable Preformance Box w/boost module, Boost Elbow, 4" Exhaust Split Into Two 3" w/5" cans, K+N Scotty Style, Exhaust Blanket, Bill K's Valve Body, Mopar Tow Hooks, Factory Fog Lights, Front Bumper Step, 55 watt Back-up Lights, Etc, Etc... .
tim , again that pesky speed sensor code you had in the puter is rearing its ugly head , could also be the problem with your NO SHIFT problem ... jack the truck up on the drivers side , front and rear , this will put trans fluid to pass side . in the OD unit you will see a wire plugged into it pointing towards the ground , un plug the wire and unscrew the sensor , if its got all kinds of metal on it , you may have a problem in the od unit . the other speed sensor in in the rear housing on top of the case , pull your cover , have a mag hytec on it yet ? if not , its probably a good time to dump oil front and rear , check for lots of metal on that rear sensor , they are both magnetized ...
John, she is going in this week (at the latest saturday #ad
, I hopefully will pull the sensor out tomorrow and look for frosted flakes. I know the rear is clean #ad
