O ring on throttle shaft, is it anything special?
Tie Rod Needed
Front signal light lens
I already have a complete VE gasket kit that I only used that o ring out of, and of course my "new" truck has the common leak by the throttle shaft. Any automotive o ring should be fine, as long as its the right size, right?
I wouldn't trust an automotive 0-ring, it might not stand up to the diesel. It might need more than an o-ring. On a lot of these trucks the shaft and/or the bushing wear out. I was lucky, I only needed the o-ring. When you get it apart, check the shaft play.
dpuckett said:
For <$20, you can get an entire seal kit. You may need the throttle shaft bushing kit, like Pete said.
Daniel
In my original post I stated I already have a complete VE seal/gasket kit minus one o ring, did it on my last truck :) . I have the upgraded bushing laying around also, bought it for the first truck and didn't need it. This leak happened on 2 trucks of mine that sat/sit a lot, maybe that has something to do w/ it? Who knows, its always a good excuse to put a 366 spring in there anyways :cool:
Duh- guess if I read the ENTIRE post, I'd not stick my foot in my mouth so much.
Is there another seal in the kit that may fit?
DP
The local pump shop might sell you the one you need. Depends on how friendly they are. I use the shop my company uses, so I don't have any problems. You might want to get 2, then you will have a complete kit. ;)
