OBD-II Connector Pin-Outs
Shut down temp...include ambient or not?
stock wheels
Does anyone have the pin-outs for the OBD-II connector? I am looking at some software that should allow us to display and RESET DTC's. Here is the link... sounds good but until I can test it, who knows... . http://www.obd-2.com
I think this is our pin-out (ISO) but I'm not positive, can anyone confirm this?
1 8
oxoxxoxo
9 16
oxooooox
pin 7 data
pin 16 power
pin 4,5 ground.
Thanks,
Mick2500
2001 2500 ETH/DEE, QuadCab, 4X4, SB, LSD, 3. 54, SLT+, Sport, Intense Blue PC/Agate, Tow Package, Camper Package, 'DC' Bed Cover, Sliding rear window. Ordered 5/01/00... Cancelled 5/30/00... re-ordered 6/02/00... Cancelled again by DC 6/05/00
Gauges (EGT/Boost) and A-Pillar mount Here, 4" Exhaust, Here.
UPDATE!! Re-ordered 7/7/00..... Finally a new VON,
Status BX 7/11/00,
Status D 7/12/00 (I now have a VIN)!!
Mick. .
I wish I could help you out on the pinouts...
I just don't have the info handy...
I could find it though. . as I have it around here somewhere.
I did buy an off the shelf OBDII scan tool. and tried it out... .
Search my old posts for "Actron" "OBD" . . ect... ect... .
What I found out was that while the connector in our trucks is OBD-II Compliant... the cummins ECM WILL not release it's codes without a special protocol...
I tried the scanner out and it found no codes at any time...
I even set one by removing the MAP sensor While the truck was running and the "check Engine" light came right on. .
When I scanned for a code. . the scanner reported none. . (all the while the "check Engine" light is staring me in the face!!
If you have gotten beyond this... PRIVATE E-MAIL ME!!!
I Want to talk to you... .
This could be a GREAT Project!!!!!!
Larry
Larry,
I sent you a note. I thought that any of the service manuals would have the OBD pin-out. Surprised no one has found it.
Mick2500
Status BX 7/11/00,
This is from a handout from an OBDII class.
1 manufacurer pin
2 bus +line, sae J1850
3 manaufacurer pin
4 chassis ground
5 signal ground
6 manufacurer
7 K line, ISO 9141
8 manufacurer pin
9 manufacurer pin
10 bus line, SAE J1850
11 manufacurer pin
12 manufacurer pin
13 manufacurer pin
14 manufacurer pin
15 L line, ISO 9141
16 vehicle battery positive
[This message has been edited by kaffine krazed (edited 07-19-2000). ]
Kaffine,
Thanks, but we already know the OBD-II standards, just need to find out how Dodge uses it. I'm pretty sure it's like my diagram above (ISO) but I'm not positive. I ordered a 2001 service manual today, hopefully it will be in the electrical diagrams.
Mick2500
Status BX 7/11/00,
According to my '98 SM, the Data Link Connector\under the dash has the following pin-out:
3 - CCD BUS +
4 - Ground
5 - Ground
6 - SCI Receive
7 - SCI Transmit
11 - CCD BUS -
14 - SCI Receive (Diesel)
16 - Fused B+
The other pins have no apparent connection. Whether or not this is the OBD-II connector, I dunno.
I got this is straight out of my 1999 service manual Page 8W-80-27
"Data Link Connector. "
16--------9 (top Row)
8----------1 (bottom Row)
Cav---circut---------function
3----D1 18VT/BR-----CCD BUS(+)
4----Z2 20BK/LG-----GROUND
5----Z12 18BK/TN----GROUND
6----D20 20DG-------SCI RECIEVE
7----D21 20PK/DB----SCI TRANSMIT
11---D2 18WT/BK-----CCD BUS (-)
14---D220 20WT/VT---SCI RECIEVE (PCM,DSL)
16---M1 20 PK-------FUSED B (+)
I Hope this helps you out!!!
PLEASE get back to me...
I NEED THIS SOFTWARE amd CABLE !!!!
It will be the most used tool in my toolbox!!!!
Larry Quinn
